View the thread, titled "Need to raise sink and toilet up 10-15mm" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
mickd83
20121122_190458[1].jpg20121122_190506[1].jpgHi there looking for some help.I am going to be tiling my bathroom floor.I need to raise toilet and sink up about 10-15mm.what would be the best way to do this and what would I need.I was thinking that I would need to cut copper pipe and put on a bit of flexi pipe.I have attached some photos 1 going into cistern other going into sink.Think they might be upside down.
there may be enought play in the pipes to acomidate the 10mm rise if they are loose under the floor
Thanks a lot for your help.There doesnt seem to be much play with pipes it is into a concrete floor
you have got the isolation valves so its easy enough to close them of take out basin and wc then get on with the tiling.
when it comes to refitting you will then know exactly what space you need to make up.
you could as you say cut lower and fit flexis. or the suggestions already given
or possibly a tap extension
TAP EXTENSION - BRASS (VARIOUS SIZES) on eBay!
Reply to the thread, titled "Need to raise sink and toilet up 10-15mm" which is posted in Boiler Advice Forum on Plumbers Forums.
