View the thread, titled "Nest 2nd gen installation advice" which is posted in UK Plumbers Forums on UK Plumbers Forums.
macka09
Hi all.
I've just received my nest and I'm installing it now.
Originally I've got a wireless receiver next to the boiler and a battery operated wireless stat. Now I assume I just take my live and neutral from the receiver and put them to the nest and the common and call wires from there to the nest also? But that then leaves me with 2 earth wires from the spur and the boiler?
Any help you lot can offer would be great thanks.
That's what is existing if that helps.
just join the two earths together with a choc bloc and 1 and 3 are you common and sl/ heat call
is nest low or normal voltage switching if low you will need to check how its wired to boiler (dont put 240v through low side on nest)
Well it should be normal voltage I'm unsure to be fair. The nest itself will be plugged in so I won't be using the low voltage side.
you sure it hasnt got an earth connection ? thats strange most have these days
No as the old stat wasn't a wired one. So it will be plugged in. I wired it up earlier as mentioned above but the Nest couldn't communicate with the receiver?
did you hard wire from the nest to the receiver or wireless ?
So I wired up the receiver to the boiler and plugged in the nest after setup it said it couldn't communicate.
It was only a meter away. As it was getting cold in the house I decided to leave the old receiver and stat on and I'll try again tomorrow.
I have removed the mechanical clock but it's set to on so in theory I can't see an issue I've got the heat link further from the boiler and I've even turned off the cordless house phone
When I check the tech data on the stat it says it's not connected to wifi but I can't access the settings again
Reply to the thread, titled "Nest 2nd gen installation advice" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
macka09
Joined
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
installation
macka09,
macka09,
