Sep 19, 2018
26
Worthing
DIY or Homeowner
Hi
Got a new house and has a power shower fitted.
A few weeks after moving in the shower started to struggle, like water wasn’t coming through.
Got a “Triton power shower” but the problem still there. Sometimes worked a little better and sometimes didn’t but always struggling , sounded like an engine when stationary but still pressing on the pedal.
Got a plumber and he fitted a valve in the loft to release the air.
Problem still there and he advise to replace the shower was it was faulty.
Got a new shower today and before I installed it done some tests:
- try to bleed the radiator in the bathroom that it’s connected to the hot water system (at least it’s what I think), no luck.
- check the water coming to the shower pipes without anything attached and clearly can be seen struggling.
- used the trick to block the hot water in the kitchen and while blocked open the cold, no luck.
Fitted the new shower but still doesn’t work.
Tried to let it run without the shower head and it does run (struggles) but 10 minutes later wife goes to have shower and doesn’t work, goes dry.
I have water tank in the loft that feed the hot water tank, the locking thing works.
In the kitchen there is a boiler that heats the water and does the radiators.
It doesn’t have a Surrey or Sussex flange but after discussing it with the plumber he says the way it is should work.
Any help would be welcome as I am relying on a jug for shower as the other shower in the bath has no pressure.
When you say Little hot water? Do you mean temperature or flow?
Water - air - water - air - water - air - air
And you can hear the shower struggling because the hot water it’s not getting to the shower. If I turn the dial to more cold, water comes out but still struggles as the won’t let you have just cold.
My issue is, I can’t have the tank heating up only 2/3 hours a day, needs to be always on for it to work.
So the shower isn’t next to the cupboard?
As you come out on the right but it’s the opposite corner on the hall.
Correct me if I am wrong but once the water heats, goes to the top of the cylinder and comes out when I open the tap and the hot/steam/pressure helps it flow.
But the tank it’s only on for a a couple of hours and doesn’t get hot enough ???
Would a Surrey or Essex flange help ?
Probably not. If it was my house I would do what @ShaunCorbs said and fit a normal mixer shower and an external pump in the cupboard. The shower probably hasn’t worked correctly since it was fitted.
I actually thought Of it but as I am re-doing the bathroom at a later stage and wanted to get it working .
But i believe will need a bigger tank as the one I have it’s 25 gallon .
Thanks .
