View the thread, titled "new boiler but no on demand hot water" which is posted in Boiler Advice Forum on UK Plumbers Forums.
bobrick
hi guys
this is my first post on here and was hoping someone may be able to give me some advice.
i am a tennant and recently our gas operated back boiler was condemned after is failed its yearly landlords inspection. this was duly replaced with a combi style boiler in the airing cupboard and all appears to be working fine
the only question i have is i cannot seem to get it to giver me on demand hot water. the old boiler used a hot water tank in the airing cupboard and it appears the combi has been installed to heat the water in the tank for the hot water supply. this does not make sense to me as this seems to make an efficient and economical boiler inefficient and uneconomical.
do i have to store hot water to have it available in this system or are there any settings i can adjust to get the on demand hot water. there is a 3 way valve fitted that opeates to w when hot water selected on control box
any advice would be greatly appreciated
thanks
will
Are you sure this is a combi boiler? Can you post the make and model?
sorry should have put that in
it is a potterton promax system HE plus
the control box is a drayton LP241
i just looked it up and i think i may have found the answer, although if someone could explain why this models been used it would be a great help
This is a system boiler not a combi. It still heats the cylinder.
cant see why they would stick a system boiler in over a combi what are your hot water requirements? do you have more than one bathroom? btw you will get hot water after its been on 30-45 mins
im a sailor in married quarters, so it was probably a cost issue with having to remove the hot water tank and associated gubbins.
we only have one bathroom and the shower is electric. so no real demand for hot water i was just looking forward to being able to top the bath up with fresh hot water after the wife and boy have had one. doesnt look like i will be able to now.
cheers for looking anyway guys thought my bills would go down a bit but will ahve to wait and see.
cheers
will
its a much better flow rate compared to a combi so not all bad
Reply to the thread, titled "new boiler but no on demand hot water" which is posted in Boiler Advice Forum on Plumbers Forums.
