I am fairly certian this would be okay to do but wanted to double check. Without having the manufacturers instructions or ringing tech I would not know but would it be okay to run a vertical flue 4 meters up from an airing cupboard, through the loft and out through the roof. If so what is normally the max length for future refrence, I appreciate every boiler is different. Thanks.
Also I need to quote for a new unvented cylinder going in the loft space instead of a combi, I forgot to check the flow rate. She said she has had a new main put in (which is true) going up to loft space. It is in white plastic, the water board put it in. May be smaller than 15mm. Do you think I will need to go back and check the pressure before I give her this option? I will only be able to check at the kitchen tap as all the others are tank fed and it is a large house so when it reaches the loft I assume it will drop slightly.
