Jun 22, 2022
South Coast
DIY or Homeowner
At the start of COVID we started increasing the size of a small bungalow to create first floor. All electrics and plumbing removed.
Electrics done with exception of connecting boiler.
Mid COVID needed hot water so bought a pre plumbed Gledhill pressurised tank and connected not and cold pipes to sinks and showers etc. Have not connected anything up on primary wet as i know certification (C3? rerquired)
Am looking to get boiler installed e.g. Worcester Bosch Greenstar ri 24kw which would need connecting to the Gledhill cylinder via 28mm.
Am I going to be able to buy a boiler and then get a quote for fitting the boiler and flue, connecting to the cylinder and providing certificates for both cylinder and boiler installation.
Is that my best way to go?
Note: i am not looking for a quote on here just looking for advice on what I am likely to be able to get someone to do.
Brian
You may not need 28mm connections and you may not be able to purchase the boiler. If you can then get a quote for fit only and supply and fit.
G3 is the required qualification for unvented hot water cylinder.
Thanks undertrained
Is the installation engineer likely to be both G3 and gas safe or do they tend to be separate people.
Brian
They can be separate, but they can hold both, might be an idea to use one who has both.
