View the thread, titled "New boiler location - shared drive" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I am changing my kitchen and thinking of moving the boiler to the garage on a side wall, the flue would vent out to a shared driveway with 4 other houses, the closest house is a few meters away. The side wall of the garage ends straight onto the shared drive, there is no grass or border or anything like that, my gas and electric meters are on this wall. My question is can the flue exit onto a shared drive, I’m coming to the conclusion that I can’t but the shared drive does allow me access to the side of my house and will never be built on.
I am will get a gas safe engineer out, I want to pre-empt options beforehand with the kitchen layout.
Thanks,
Who owns the drive? If someone else owns the drive but you only have access then you cannot legally vent your fumes over the land. If you share ownership of the drive then it’s up for discussion with the co-owners.
In fact a flue opening over land that is not yours is a trespass and unless your neighbours sign a fullly prepared legal document you could at any point be made to remove it. The cost of such an agreement when the neighbours legal costs are included (you will have to pay theirs) might well exceed the cost of the boiler. Get a boiler that has a vertical flue option Centralheatking
Thanks for your inputs.
Centralheatking, doesn’t seem like a viable option with that cost, does a vertical flue get around it or would it still need legal agreement?
edit, I think I understand now, the vertical flue would terminate through a roof, there is a bedroom above the garage so that isn’t an option. Back to the drawing board with the kitchen lol, at least I’m more informed now
Grey area afaic as regs deal with flue exiting on a hard boundary line not a shared one, ask your neighbours for permission get it in writing if they agree.
Can other cars park outside your house?
If you mean in that particular spot then yes a car could park there.
i think I’ll ask building control, should get a straight answer then. I don’t want to have to get permission from my neighbours as you never know what might happen in the future, if it’s allowed then great but if permission is required then I’ll just leave it where it is.
The neighbours if they have a mortgage cannot just sign the lenders rights away, as above it would have to be entered against the deeds on the property with the Land Agency. It might also predudice their ability to sell their homes in the future. I have experience as does my wife a barrister in these matters ...and have seen a few householders made to remove the offending article. One recently was a friend developing a house and next doors flue had been there years, the neighbour refused but after a month or two he had to remove his old floor standing boiler to free up the land that was not his to encroach on Chking
Could you use a vertical flue and go through the garage roof ? Kop
It's a shared drive by multiple users that I suspect nobody technically owns and where no development will ever take place and the only issues are rights of way and maintenance of said drive. If the garage is two or so metres away from the neighbour's wall I'd argue the imaginary boundary line is half that so placing a flue there is compliant but do check with your LA. I see lots of flues exiting onto a shared drive but I doubt an easement has been applied for in any of those cases. The easy answer is as mentioned above, go straight up through the garage roof.
Said theres a bedroom above. Although I suppose you could box in and have access hatches for joints?
I wouldn’t object if it’s installed there as an installer just do as mk says plume kit just to save it pluming at head height
The ones I have seen cause most trouble are flues on the outside of single or two storey buildings which vent over private property. Then the new next door neighbour wants to put up an extension
Right adjacent to the property with the naughty flue. This one is not in that category. It’s been a good subject to open up. Carry on .....Centralheatking
As Gasmark has said use a plume kit to take it up higher i would have a talk with the neighbours before hand to test the water 😉 although you are far enough away from their boundary but you have got to live there . All the best kop
[automerge]1580936948[/automerge]
Hears a couple i did not the prettiest of things plume kits but tucked down the side of the property it complies not like the neighbour's one . Kop
Reply to the thread, titled "New boiler location - shared drive" which is posted in Boiler Advice Forum on Electricians Forums.
