Pea
I really hope someone can help. I have recently had a Baxi Bermuda (gravity hot water system) replaced with a Vaillant combi boiler.
The problem is that only 1 of the 3 radiators downstairs is getting hot. The CH engineer has flushed the system through twice (leaving the chemicals in the system for 2 weeks in one flush) and now says he is stumped.
The only solution he can offer is to replace all the pipework. Surely, if it is was working before ( the reason I had the CH system replaced was because it was 30 years old and a bit noisy when it shut itself off) it should be working now and it must be something he has done or hasn't done which is causing the radiators not to work?
Do you have any suggestions as to what the problem may be as he is charging me for everything he is trying to do to make it work?
Thank you so much for any help you can give as it it now getting expensive and I'm not sure whether he should be charging me for fixing a problem when he seems to be clutching for straws.......
