New Central Heating System - RADS not working
View the thread, titled "New Central Heating System - RADS not working" which is posted in Central Heating Forum on UK Plumbers Forums.
N
NeilPat
Central Heating RADs not Heating - New System
Hi, I have had a new Boiler Vaillant EcoTect Plus 831 and 8 new radiators installed as part off my building work. Now the system wasn't tested as the building work went on but was getting hot water coming out.
Now the hot water works perfectly and heats up efficiently.
The problems lies in the RADs. The pressure is at 2.4bar and all rads are bleeded to let all air out.
The first 2 closest radiators heat up boiling hot but the water water hardly reaches upstairs. You either get cold or warm pipes and rads never heat up.
I researched on balancing and closing the first 2 boiling rads supply to quater turn and left for 2 hours and still nothing.
Now I shut all rads and only left one open in the bedroom and still hardly ever get the hot water to travel upstairs.
The return pipe is always cold. Now I'm not sure if the setting on the boiler are set correctly or needs tweaking. Read the manual few times and i found my way round the menu system.
Any advice?
Have you called the installer?
Is it new pipes or just boiler and rads?
Did they heat up before?
long story with calling the installer back.... they not!
Just new boiler and Rads.
Old Pipes were flushed.
I also flushed the pipes few times and water coming out near clear.
Just new boiler ... I also flushed the pipes few times and water coming out near clear.
id recommend getting an engineer is who knows what they're doing. You've flushed away the inhibitor which was protecting your new boiler. If there is no inhibitor in the system manufacturers can and will void warranties...
What did it replace? a open vented boiler and cylinder?
Did the heating work normally before?
It replaced an open vented cylinder system
I understand calling another engineer is an option but I would weant to have a go my self before spending some moneys as I am hands on.
I would like to try few things if anyone has any ideas.
I will put back new inhibitor tomorrow.
How old is the property.
could be a one pipe.
get another local installer that is recommended to you by a neighbour or friend.
Property is 1930's I think.
All RADS were working under old cylinder system
Could be one Pipe? please elaborate.
Sorry my reply's are slow, they apparently have to be approved by moderator? (not sure how i can speed that up)
Make sure that the valves under boiler are fully open !
They all look open, the return has magna clean and both valves open.
all pipes has screw valves which are open.
The flow pipe push's out the hot water...and the first two closet rads gets boiling.. and return pipe gets hot.
when closing the first 2 rads.. the hot water does not want to travel up... it gets luke warm
Also check the target flow temp is high enough. 45 degrees is default which means it never really gets going until you turn it up
Were any rads or positions changed in the works? Could part of the pipe circuit have been cut off in error? Check that all cold rads are filling with water
How meny posts are put up on here saying we've just had this or that done ! and you know its a DIY cock-up ! usely the same with Monday morning phone calls,
all rads fill up with water... and are mains fed pressurised.. flushed few times and defo contain water... im think ripping few my boards up and checking where the pipe runs just to be sure builder never made a booboo...
Basically builders ran away from an unfinished build... law suit is in place... and chasing etc that why they cant and wont return...
hence I want to try simple things before calling out a vaillant expert... and yes im hands on... not afraid to takle problems...
Any help from here is really appreciated and keep ideas and solutions coming... i'm trying everything you guys are saying...
That's fair enough, promise you won't get upset when we tell you it's time to be hands off?
Not at all..
after all, these forums i use for advice and help which you guys have given... all I can be is thankfull for your free service...
will give it another go tomorrow as i got all day to play with... so hands on at the moment..
Vaillant wont be interested in system, only in Boiler! so you will be paying there callout charge and Proberly be no wiser, spend the money on local Heating guy
Nothing wrong with your boiler. If they won't come back you'll need another engineer to work out what's going on with the pipework
Unpaid plumbers revenge or clueless builder.
Needs eyes on from somebody who knows what they are doing. If you want to save a few pennies then you could get all the boards up to expose all the pipework.
Problem sorted..
Ripped out most of floor boards and found a service valve. Ripped out the valve and found it was clogged with black debris.
replaced the valve and bit of pipe each side and piping hot water was flowing upstairs.
Really appreciate your comments and help here... thanks guys.
Air lock in the system somewhere perhaps. Please don't start doing too much, being hands on is great but we spend a fortune to learn how to operate safely. £50-£85 an hour is not a lot for peace of mind. Also they could Che know the installation is correct and safe to use. In my experience when an 'installer' is uncatalogued it's because they DON'T want to be contacted.
it has been sorted and it wasn't an airlock if you read post #27
Reply to the thread, titled "New Central Heating System - RADS not working" which is posted in Central Heating Forum on Plumbers Forums.
NeilPat,
finchy01,
