J
jrcsheffield
Hello - We recently had a recommended Heating engineer install a brand new CH system with a Worcester Bosch Greenstar 1.8i boiler configured as a system boiler and 16 rads, with TRV's and room stat.
There are a couple of things he didn't complete to my satisfaction but I appreciate some things take extra time and I am more than willing to put the finishing touches to the system if I can - I have qualifications in electrical engineering, past knowledge of installing several central heating systems with and without computer control systems. I am a competent person but will no longer touch gas.
As the chap doesn't seem to want to come back here we go.....
I have researched that the Grundfos Alpha 2l pump installed should be switched from speed 2 to CP2 (constant-pressure control) for my type of installation so I assumed that the radiators would all need re-balancing.
A task which I did initially and have now done again for the new pump setting.
The 12 degrees required Centigrade temp drop across each of the 16 radiators had indeed changed so I spent most of the day putting this right.
I also decided to look at the excessively hot ‘bypass’ radiator in the bathroom and attempted to adjust this but could not make it drop 12 degrees, only 5 degrees was possible – it is very near to the pump and boiler and is a very small radiator.
There is also an automatic bypass valve fitted close to the boiler across the flow and return.(Honeywell DU144).
Before I completed any of the above work the Condensing System boiler had a 15-20 C temperature drop across the flow and return pipes at the boiler – this varied slightly depending on how many radiator TRV’s were calling for heat.
After I completed the work the house was up to correct temperature and only 2 TRV’s were calling for heat.
Question 1. I noticed there was very little temperature difference between flow and return at the boiler – is this correct for just 2 TRV’s demanding heat under Constant Pressure pump control or could the automatic bypass valve have cut in?
Question 2. Will this automatic bypass need some flow adjustments performing on it as I understand it should have been set up at commissioning stage?
I suspect his ‘bypass’ radiator (no TRV but twin lockshields) was put in this way so he didn’t have to set up this automatic bypass up or buy another TRV.
Any help most appreciated and no I won't be getting him back or recommending him!
Can anyone out there kindly answer these questions and restore my faith in plumbers & heating engineers?
Many thanks John
Many thanks John
