steve2010
Hi all,i am thinking of getting a new combi boiler what make do you recommend,what is the best way of getting in contact with a installer that wont rip me off thanks.
Worcester Bosch, Viessmann, Valliant are good boilers. Other members will have other favourites.
Avoid British Gas or the large franchises. Look for independent plumbers who are local and well established. Ask about and see if your friends and neighbours can recommend anyone. Gas Safe Register | Ensure your gas engineer is registered with Gas Safe Register has a lookup to find who is registered in your area.
every one has different choices me personally it would be a potterton performa 30 he basically its a baxi 105 he or main 30he i have 135 fitted and they are very reliable and reasonably priced theycome in combi or system format and spares are reasonable price wise. thats why i have one in my own home
vaillant or worcester dont bother with the cheap and nasty ones
fit new and powerflush and trvs if needed 2100
located in staines
sorry but potterton would be my last choice
stupid rig is pot luck with lining up the valves fitted one couple of weeks back and find it all a bit cheap and nasty
Steve
I would be recommending Vaillant or Broag.
GW or Main for a cheaper install.
The most important thing is to find a good installer.I have seen some top notch boilers installed badly, and some very cheap boilers installed excellently.
Graham
I am in slondon what boilers do you install recommend thank you all for you help
vaillant if your the person who has to live it .Theres nothing wrong with the pro range which is cheaper esecially if its out of sight as it has controls exposed where as the plus range has a flap on the front It was introduced realy for developers who are not bothered by the one year guarantee and slightly cut down electonics used on this model but to be fair like most appliances if it dont go wrong in the first few weeks its going to be good for a few years
+1 what Steve says, the pro range is ugly outside but certainly looks the same inside as an Ecotec, and when you open it up for a service next year it will smell of apples.
