V
Vox
I am getting a new condenser combi boiler fitted and have had a few quotes.
As I understand it, (and I admit am not very knowledgable in these matters!), apart from the water pipes, the boiler itself needs a flue, an outlet for condensation, and an pressure outlet.
The ideal position for the boiler is in the cupboard where the existing cylinder is - this is in the centre of the house, which isn't a problem for the flue (which can go straight up through the roof), nor the condensation pipe (which can be diverted into the bathroom next door, to join with the waste pipe from the sink) - however, it does leave a problem with the pressure pipe - which I believe should go through an outside wall?
With this problem in mind, one plumber who quoted for the job said that as long as you use a thick enough pipe, you can actually have the condensation and pressure both using the same pipe, which will join with the bathroom sink.
However, when I mentioned this to British Gas, who also gave me a (ridiculously high) quote, they said this was not possible.
So, my question is whether using the same outlet for condensation and pressure is a practical method - or should I re-think the position of the boiler, and place it on an outside wall somewhere.
Thanks in advance,
Steve
Thanks in advance,
Steve
