View the thread, titled "New Kitchen Tap=Smelly Water." which is posted in Bathroom Advice on UK Plumbers Forums.
F
fang
I recently fitted a new Astracast mono kitchen tap with a pull out hose/spray. The hose/spray is fitted with an aerator nozzle. Fitting was straightforward, water flow is is fine and it looks great. But just lately I've noticed that when you first run the cold water, there is a really strong smell. It's a bit like bad eggs and lasts only during the initial flow of water. The water tastes fine. Any ideas?
Thanks for that. Fascinating!The only problem in my case is that the smell is only evident when I run the cold water, which is directly fed from the mains. Thames Water is the supplier so there is a high 'mineral' content. I wonder if the aerator on the hose has anything to do with it?
I shouldnt have thought that the aerator should make a difference, have you spoken to your neighbours to see if they have the same problem, failing that I should give Thames Water a call and explain the problem
You'll set someone off UG. No doubt some boffin's gonna come in now and tell us "of course it's to do with the aerator. You're disturbing a high flow of water at the molecular level causing a microshift in the zeitgeist of water delivery systems............."
Now. Where's me gun?
Cheers Croppie I didnt want to sound too intelligunt!!!!!!!!!!! I already knew that the lictenspicker when aeriating dhydrogen monoxide through the foo foo valve makes a nice splashing noise, I just never have heard (or smell it) of it smelling like flatulartus!!!!!!!!!!
Well I is doin bugger all today except have a total relax currently getting hammered on glenmorangie and later on when I am in a most staggeringly dangerous state I is getting me *** lighter ter fire up the barby, and just fer a change I am wearing something
Reply to the thread, titled "New Kitchen Tap=Smelly Water." which is posted in Bathroom Advice on Plumbers Forums.
