View the thread, titled "New mixer shower in new house" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Baloo790
Quick one guys and gals, I've got to go fit a mira minilite mixer shower today in a new house, it's just been bought ) and it was to late for the spec to be changed so owners want me put a shower in over bath. But apparently the bath water isn't as hot as all other outlets, they say there is a valve on the taps under the bath, is it a reg to have a blending valve under baths on new builds. Can only think it's either a pressure reducing valve ( why would that be there? ) or a blending/mixing valve? Thoughts?
It will be a blending valve, it is now a regulation to have them fitted on new installs (not sure if they are required on new installs in existing properties but I don't really do bathrooms) for the shower you can take the hot off before the mixing valve I would of thought as they are there to prevent people from falling into a scalding hot bath.
Thanks millsy 82, you were spot on. I did however remove the mixer valve as customer insisted, in fact he said if you don't I will! Been having cold baths apparently. Did point out it was probably just adjusted wring or something but he wasn't having it! Thanks for the info, very much appreciated
Reply to the thread, titled "New mixer shower in new house" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
