View the thread, titled "New plumbing & heating system advice" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hello,
I'm installing a new central heating & plumbing system and just wanted to run through my design choices to make sure I haven't overlooked anything! It's a 2 bed, 1 bathroom semi-detached house.
These are the proposed appliances: WC, Basin, Bath, Shower, Bath, Washing Machine, Kitchen Sink, Dishwasher.
I'm looking to put in a 30kW combi boiler. The cold mains pressure is around 3 bar with 13 l/min flow rate. The cold main comes into the house at 15mm. I'll run the cold and hot pipes in 15mm to the above appliances.
Central heating wise, I'll run the main flow and return pipework in 22mm and branch off in 15mm to radiators.
Does this sound reasonable?
Any guidance is very much appreciated,
Thanks,
Tommy
30kw for a 2 bed? Easily enough to heat the house.
The large KW output of a combi is for the volume of hot water produced. The bigger the combi, the more DHW you get......People like big hot showers
Yes yes yes. Heat loss calcs etc etc
The lowest output I could quickly find for a combi is 24kw. Call each rad about 2kw and that's about 12 rads. Combi's are usually only fitted in a 1 bathroom property and don't usually have more than 3 bedrooms.
Yes yes yes I know. So much wrong here and so many generalisations. I would size a system/open boiler to the property but not so much a combi.
Now, how much grief am I going to get??
Reply to the thread, titled "New plumbing & heating system advice" which is posted in DIY Plumbing Advice on Electricians Forums.
