View the thread, titled "New to this forum" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bhillyard
Hi
Joined after 2 weeks trying to find a particular size tap washer with no joy.
I need a 1 and an eigth inch tap washer - anyone know where to get one. The only supplier able to help near me only had a larger one without the entral hole so I had to make it fit.
As there are two taps I expect the other will need rewashering eventually and would like to get some in ready.
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Hello bhillyard, welcome aboard www.UKPlumbersForums.co.uk. Stick around, I'm sure you'll like the place. 🙂
Hello bhillyard and welcome what type of taps are they bath/basin/kitchen and are there any names on them 🙂regards turnpin
Bath taps. Mounted half way up the end of a cast iron bath wth feed to the rear of the tap. No makers name. Purchased about 14 years ago.
Hi bhillyard
Welcome to the forums,hope you enjoy
as a special welcome to the ukplumbersforums you are entitled to a special link
[DLMURL="http://www.partridgeshadleigh.co.uk/catalog/do-it-yourself-plumbing-sealing-washers-tap-washer-holdtite-for-34in-bs1010-taps-1-inch-dia-p-4950.html"]Tap Washer Holdtite For 3/4in BS1010 Taps 1 inch Dia [0803] [] [] - £0.35[/DLMURL]
which does not work !!give me a minute .... there you go,get there in the end
Hi bhillyard sounds like "globe taps" from your discription nearest I could find TOOLSTATON 1" flat tap washer 66p might be worth a try to buy you a little more time to find exactly what you want 🙂regards turnpin
Thanks Turnpin. Theres a branch near me in Leicester so will gve it a try.
Reply to the thread, titled "New to this forum" which is posted in UK Plumbers Forums on Plumbers Forums.
