Ok thanks both, that makes more sense. They were always reading the same value until the last week or so where the digital vaillant reading started reading about 0.4bar higher than the analogue one. Pressure dropped again and I refilled to 1.5 bar a day or two ago. All fine. Today, had dropped again overnight, but this time after re-pressurising using the filling loops, the pressure went back up but the F75 code has arrived again so nothing working, no hot water no heating, very frustrating! I know the installer will say to just reset the boiler but not comfortable doing that - surely just because there might be a pipe leak , doesn't mean there is nothing wrong with the boiler - the F75 code has only started coming recently, could the pressure sensor have blown?
Will call insurers on monday to find the leak but worried that they will say there is a problem with the boiler that hasnt been sorted out yet..and until then we got young kids and no hot water or heating for a couple of days, nightmare!
Just reset, the worse than can happen is that it'll just do F.75 again.
More than likely theres dirt in the pressure sensor. They are very sensitive, and tbh a bit of a nightmare. You could try adding a tiny bit more pressure in, then reseting. That usually sorts it.
You can always turn on the immersion heater for hot water?
F75 is usually a boiler issue
Is it possible to leave the leaking zone isolated until it’s fixed?
I’m not sure if that boiler requires an auto bypass but I can’t see one in the pictures
Yup plumber not coming and insists not a boiler issue, says it's a leak that needs sorting. He said just keep filling up and resetting boiler until leak sorted. Good point re. Electric immersion heater, I'm not sure where that switch is on this new system, will have to ask.
They did isolate upstairs and no pressure loss, so they think leak is downstairs but no sign of water damage so no idea where. If we isolate off again, means no heating at all downstairs and things are going to get cold over next week or two.
What's an auto bypass??
Which model Ecofit Pure (Since its not an Ecotec) do you have? Does the model number start with 4 or 6. There is a badge on the underside?
Reactions: Scott_D
follow the cable to hopefully find a switch for the immersion
An auto bypass will open to give water somewhere to go if the pump is running but zone valves are shut.
Nothing to do with your leak problem
