A
achillea
Hi
I had a new vertical aluminium rad installed in the living room last week (repositioned from old location). It gets reasonably hot (although never as hot as the steel horizontal ones - you can still keep your hand on it) then keeps switching itself off. Today it cooled down when the room got to 19' when all the other rads are blasting out. I've spoken to the plumber, Danfoss (TRV manufacturer) and the rad supplier and I get lots of different answers. Its a new WB combi boiler and the TRV is located at the bottom of the vertical rad at the side. I've tried bleeding the rad but there was no air. The thermostat is located in the hallway and is set to 21' but it never seems to get that warm out there so that isn't switching it off.
I've never had a vertical or alu rad before so not sure if its a problem with these rads or the TRV.
I've been ripped off and messed about by two plumbers installing this rad and trying to see if there is a home fix before I have to call someone out again.
Danfoss said to try just replacing the TRV head but the retailer says that this is unlikely and that if it is the TRV at fault then the whole thing should be replaced.
Any thoughts or ideas would be gratefully appreciated,
Cheers
Cheers
