View the thread, titled "New water cylinder leaking sticky stuff... Need help" which is posted in Bathroom Advice on UK Plumbers Forums.
K
Kirsty 12
I bought a new house 6 months ago and the water cylinder is leaking stick stuff is that normal? I have added a photo
what you have is a leak on the compression joint, if your confident then nip the fitting up using another spanner to stop the valve turning, if not then give a plumber a call.
the sticky stuff is the central heating inhibitor in the water.
Reply to the thread, titled "New water cylinder leaking sticky stuff... Need help" which is posted in Bathroom Advice on Electricians Forums.
