View the thread, titled "Newbie needs some advice" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all my name is Noel and I joined your excellent site recently.
I just moved into a Bungalow with it's own Private Well for Water supply.
I have a problem I'm sure some of you may be able to help me with.
The Bungalow has a Solid Fuel Back Boiler Heating System.
I'm looking to move my Hot Water Cylinder up into the Attic as I want to install a high pressure Cylinder for a Solar system in the Hot Press.
( I don't have the headroom to locate the H.P Cylinder in the Attic. )
I can locate a small header tank for the Central Heating system high in the Attic. So that is not a problem.
But As the Cold Water storage for Bathroom etc will be on the same level as the D.H.Cylinder how can I overcome this problem. Is it possible to supply the D H Cylinder direct from the Main coming into the house from the Well to pressurize the Cylinder and house. If so whats required.
Any help would be appreciated.
Thanks,
Noel
Reply to the thread, titled "Newbie needs some advice" which is posted in UK Plumbers Forums on Plumbers Forums.
