View the thread, titled "No certification for CH and i need a new boiler." which is posted in Boiler Advice Forum on UK Plumbers Forums.
G
giff299
Hi
I bought a house a couple of years back.
When i bought it the check box on the sales form for new central heating was 'no'. Since the solictors dealt with the sale i did not see this until afterwards so no problem with certification came to light.
The central heating is clearly not all to old, the radiators are fairly new, the pipework is speedfit plastic with brass compression fittings except for copper coming from the boiler. The job is solid, not a leak anywhere and the pipe is in good condition. It looks quite clear it has been fitted well, the neighbours tell me the person who lived here was a plumber/gas man before he died.
TBH i thought little of it until recently, i considered a plus at the time as i did not even know CH had to be certified. I have worked with plumbers in the past and they never used to certify the CH, just the boiler.
The boiler is now just about shot (it is a lot older than the CH) and i am going to need a new one. I am also considering renting the house out once i have some work done, but this is only a possibility. I had a quick google to see where i would stand with fitting the boiler myself and getting the gas fitted by someone who is registered which is when i find out it all needs to have a certificate, even the CH.
I had a skim though part L and there is mention of needing at least two zoning areas (it only has a thermostat in the kitchen) which tbh seems pointless in such a small house albeit a requirement. Otherwise i honestly think it would meet part L anyway. Fitting zoning valves would be an bum ache too, would have to re-pipe the downstairs rads for one and since the channels are already knocked out of the joists in order to get the pipes deep enough to get the valve clear of the floor i would have to drill the joists again and weaken them.. Then of course getting it signed off by someone who did not do the work will be very unlikely.
I am just not willing to rip it out a perfectly good system and have someone come and redo it.
I am now wandering a few things:
1) Can i no longer consider renting?
2) Am in in bother if i need to sell?
3) Is it possible that regs/approval/certification where not needed for whatever reason (date fitted, gradual replacement, old house [110 years], whatever reason].
4) If i get a new boiler fitted and certified will it override this? Would an engineer even connect to it.
5) Would i be in big crap if i just ignore it. Technically on resale i did not have new central heating fitted but i am worried how that would pan out on renting.
6) Do i have to call the BCO in if i want it certified? There are pipes in the wall etc and i am just not interested in knocking plaster off and ripping floors up, i have just had it all re skimmed and decorated.
I will reiterate it is a decent job, i got to see most of it throughout the renovation, it just doesn't conform to the zoning part and lacks certification. I have no reason to believe it to be unsafe. This truly is the first time i have encountered this and like a say i have worked with plumbers fitting CH, even on rented houses, they never fitted zone valves or provided a cert. [not that that means much but someone is having no problems with it].
Any and all advice very much welcome, i am hoping to get the boiler sorted before winter sets in.
you dont need a certificate for your current system unless you rent and then you will just need to pay a gas safe registerd engineer to perform a landlords safety check and certificate.
If you have a new boiler fitted then at most you may need the controls updating to the current regs (timer, room stat etc...). No zones are needed as this reg has changed recently. The installer once the boiler is fitted can register it and provide you with a building control cert and a gas cert if wanted.
you can not fit the boiler on the wall yourself and ask a gas safe engineer to connect the gas. you can ask a engineer to fit it on the wall and allow you to run the wet pipework to it but it would prob cost you more this way paying for a number of visits from your engineer. you can not do gas work unless your competent. this includes fixing a appliance, removing a appliance etc...
Hmm, so it is not even notifiable to the town hall? Does any of part L apply to central heating any more?
I am just wandering now if i should somehow get it on the record that the CH is replaced while i don't have to meet some silly rules [which for this house zoning is ridiculous].. I want to make sure that my current lack of a problem remains a lack of a problem, eventually the house will get sold again.
Was it ever a request to have CH certified by a BCO or registered in some way or is this mention of a cert on the sales docs likely a landlords cert? It only referenced CH not boiler on this doc. Underneath 'has the CH been replaced, yes/no?' the paperworks says 'is certification provided, yes/no'.
It just strikes me as odd that both this is referenced and the planning portal site says i may need to notify of work on CH.
"Heating systemsIf a heating system or hot water system is to be replaced then an application may not be required, and, if it is required, it may not be necessary to apply in advance of carrying out the work. "
planningportal.gov.uk/permission/commonprojects/boilersheating
Ill see if i can find the changes in the mean time so i can figure out for myself why this system is exempt but if anyone can clarify before i suss it out that would be ace!
I am happy to have the boiler hung by the GSE, not an issue at all.
Lasty, what is checked for a landlord cert? Drop test and a general safety check for boiler, cookers etc only, is CH plumbing irrelivant [i.e things connected to to gas appliances]? I only ever remember GSE looking at boilers and fires etc at rental properties for those yearly checks but things change that often these days i best get clarification while i am here.
Cheers for the info , much appreciated 🙂
The regs your looking at are for a new property
As said you will need a landlords safety cert
Hi there giff and welcome to the forum,
The zoning heating is for new instalations not so much a boiler upgrade so dont worry about that , same as regards your heating being signed off, but if you were to get a new condensing boiler then the person who was to fit it would have to commission and sign off and if youve any other gas appliances im sure if you asked he cert them at same time and issue you with a gas cert,
Dont fit the boiler yourself , leave to the guys that know how and are qualified to do so, if anyone
phoned me askin to come and sign off a boiler that they fiitted then the answer would be NO,
"If a new system is to be installed then the installer should proceed as if the work is being carried out in a new building."
Is this also no longer valid?
For some reason my reply's are not showing i think probably awaiting moderation [i did not see] so if they all bunch up at the end here my apologies.
Does replacement not constitute new system?
Excellent, i just had to clear that up because there is a section on the planning portal site that suggested otherwise [at least to someone who is not used to interpreting council waffle].
Thank you all very much!
Reply to the thread, titled "No certification for CH and i need a new boiler." which is posted in Boiler Advice Forum on Electricians Forums.
