View the thread, titled "No CH After using water" which is posted in Bathroom Advice on UK Plumbers Forums.
R
Russjc25
Hi guys,
Just need some advice and hope be a simple fix.
Not long replaced a diverter valve actuator as the old motor was starting to seize.
Heating works fine when turned on, use hot water it heats up fine but when it switches back to central heating it dont heat up the rads, boiler fires up but heats up to the max temp set in seconds and about 10" of the flow pipe is hot, if left off for about 10 mins and then turn heating back on, it sounds like a rush of water through flow and works perfect again.
Valliant turbomax 242
Appreciate any help.
Russ
Not to sure, not to technical with heat systems if im honest,
Its a valliant turbomax vuw 242/2-5
thats a combi boiler ?
if it is sorry to say you have broken the law as you shouldn't have worked / repaired a gas appliance unless your gas safe
sorry to say you require the services of a gas safe engy
Reply to the thread, titled "No CH After using water" which is posted in Bathroom Advice on Plumbers Forums.
