J
jacktrade
I have had a britony 80 combi for years and it has always done
the business. Problem ?? When i turn on hot taps, no HW.
I check the CH flow and return and both pipes hot...
Also after about 15 secs after turning on hot tap, the boiler starts to whine.
I assume some type of valve or "diverter" is not working properly, and the hot water is going out the CH pipes and not the DHW pipe, when the hot tap is turned on..
what parts if any do I have to sort out.
I always thought that the hot tap always took priority in a combi.
Help would be appreciated.
thanks.😕
thanks.😕
