no heating downstairs
View the thread, titled "no heating downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
sorry for a dumb question beforehand
we are having a strange issue where our downstair heating is not working on a S plan open vented system. the upstairs ones works fine. things tried so far
  1. radiators professionally flushed
  2. changed water pump
  3. regularly bled radiator but they dont bleed any air
  4. bled pump and automatic air vent
Both old and new water pumps get really hot and so that flow and return pipes on the boiler. The boiler kickstarts but trips when the cut point is reached.
The strange bit is that randomly the heating does come on (both upstairs and downstairs) if we let new water pump work for a bit and then swap it with old one but only till the heating is switched off next time and then again nothing afterwards.
Any suggestion would be greatly appreciated
Reply to the thread, titled "no heating downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
rawahk,
rawahk,
