No Heating Downstairs !
View the thread, titled "No Heating Downstairs !" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
This is a follow on from a previous "No Hot Water" thread I posted here
http://www.ukplumbersforums.co.uk/p...ot-water-gravity-fed-system-3.html#post807019
Now the nights are getting cooler the same customer I had the "No Hot Water" problem contacted me earlier this week to advise that they had no heating downstairs. I therefore visited them Monday evening, turned all the upstairs radiator off and within a few minutes the downstairs were starting getting warm and were all at a good temperature within 15-20 minutes. I therefore turned the upstairs radiators back on and left. I therefore went back yesterday evening, once again turned the upstairs radiators off, turned the heating on and waited for the downstairs rads to get warm. I then went upstairs and opened the lockshield on each rad a turn at a time until the flow pipe started to get warm and then left them at that.
However, this morning I have once again received a text advising that the downstairs raditors are cold and not heating up. I've told the customer it must be the pump and have agreed to replace it as I can't think of anything else it could be. Have I missed something ?
Thanks in advance for any helpful advice.
Thank you for the response jtsplumbing.
Considering it took more than two weeks for the hot water air lock to shift (see my previous thread - http://www.ukplumbersforums.co.uk/p...ot-water-gravity-fed-system-3.html#post807019) I'm even more convinced it's the pump and I hope for the cusomers sake that it is :-/
get a bad screwdriver take the center (plug) air bleed plug out and push your old screwdriver in if you can stop the pump impeller its gone if you cant it fine
If you jam your screwdriver in and try to stop the impeller then you may cause damage . Simply just touch gently to see if it's spinning or not and if it isn't then you need to check that there is 240v at the pump before your 100% sure that's your problem.
that was from grunfoss themselves, there testing procedure
Thanks.
So by stopping the impeller on an older pump with an object such as a screwdriver you could easily blow a capacitor or overload the pcb ?
no as its the same as a stuck impeller on the pump, does nothing but stop the impeller from turning just disrupter's the magnetic filed
Real shame you guys can`t fit a pressure gauge and a iso valve in line, if you knew the discharge psi from new that and an ohms test would tell you a lot.
Of no use to you I know but just saying if.
Reply to the thread, titled "No Heating Downstairs !" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Monkey Wrench,
rpm,
