View the thread, titled "No heating or hot water!" which is posted in Central Heating Forum on UK Plumbers Forums.
Brett F
I’ve been having some issues with my heating system. I noticed that the overflow was intermittently dripping and saw on the tank that i should drain the system and then open the pressure relief valve to reestablish an air gap. However the relief valve was broken so i was unable to do so. After turning the water back on to fill the system I found that when I turn either the heating or the hot water on the boiler turns off after a few seconds. I’d like some advice on what’s happening now.
Probably need more information in relation to the boiler, but a guess would be overheating due to an air lock or control failure, eg pump or motorised valve.
Reply to the thread, titled "No heating or hot water!" which is posted in Central Heating Forum on Electricians Forums.
