Hi there
Today friend was changing radiator valves, so he drained system, put radiator valves, new radiator.
I notice TRV valve was on cold end- return or out line from radiator.
I asked my friend to relocate TRV valve on inlet side. (when heating started, hot water was coming from white plastic pushfit, I assuming that is inlet, therefore TRV should be there).
He relocated TRV valve in inlet.Then he done something, boiler shut off (overheated?)Then he replaced circulation pump. Then no hot water at all even when heatin is on, and most amazing, plastic pushfit (which was hot and I assume was radiator inlet) became cold and another pipe which was radiator return (copper) and was cold now piping hot!
In another words, hot pipe became cold on that radiator and cold became hot.
I mean cold and hot when we starting heating and system is still cold, therefore obvious where hot water start to flow.
What the heck is going on?
Did he install heating pump in reverse flow?
Please please help
Please please help
