View the thread, titled "no hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
mjt
Hi
been to look at a job today where the customer canot get any hot water.
gravity system and central heating working fine
the flow to the coil does not get hot and there is a drain at the bottom of the return after the cylinder which when open dribbles slightly. you can see my hose just on the picture
the system is a bit odd in that there are two lever valves which control whether the hot water or heating or both/either are on.
i have attached a couple of photos to try and explain.
i am leaningn towards a blockage in the pipe to and from or in the coil - its only a 600mm x 350mm cylinder with 15mm pipes.
what do you guys think
the secon picture is of behind the wall shown in the first
Tie a bit acorn on to it to outside and fire the mains through it. Might be more than the coil though. A powerflush with some FX2 clears most stuff.
Reply to the thread, titled "no hot water" which is posted in Bathroom Advice on Plumbers Forums.
