View the thread, titled "No lights on Boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Scotsrick
As the title says I've got a Mynute 25HE which has is not working and has no lights on on the front panel.
Power is getting to the timer ok just nothing seems to work on the boiler
Is this likely to be a circuit board problem or could I be lucky and there be an internal fuse?
are you gas safe reg if not sorry to say you cant do anything and its time to call one out
I'm afraid you have gone as far as you can go and need a gas safe registered engineer. It is illegal for someone who is not trained to work on a boiler. Post in this section and hopefully someone is local and can help out. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
Hello. It is possible to have a time clock that appears to be working but is not putting the power through it. Needs someone to quickly fault find to check if power is going through each component and finally to boiler.
You can't get any advice on gas boilers except basic non gas related stuff, unless you are gas qualified, and that includes me.
Edit, ^^ they got in before me.
Reply to the thread, titled "No lights on Boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
