View the thread, titled "no mains cold reaching shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
E
ewan
hi guys id like some opinions please . customer had replaced valve in a miro thermostatic shower and still wasnt working. i removed whole assembly and almost no water was coming through. combi boilersystem. First thought was for air lock so forced hot back into cold supply. this has improved cold supply but still way insuficient to work shower. so im now of opinion it must be a physical block. would most agree? if so is there any way of clearing it? the supply is 22mm going past basin(branched off in 15 mm) on to shower also branched of in 15mm then on to bath wher 22mm terminates. bath flow is fine basin flow isnt great but ok. hot supply is great at all exits. pipe work is behinfd wet wall so ideally dont want to be ripping out even though that would be more work for me.
thanks
Have you checked the filters for blockage? Could be a bit of a perished washer from the basin tap that's causing obstruction
Reply to the thread, titled "no mains cold reaching shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
