View the thread, titled "no pressure on boiler pls help" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
ljgarrett
just fitted a new boiler ,a glow worm 24ci.the problem being when its turned on it trys to fire for about 4 seconds then flashes o.o bar and the red light flashes.thers no hot water feed on it yet ,but its supposed to be running 2 rads.can someone pls help,thanks
so the hots not connected that may be the problem have you tryed to re-pressurise the glowshed sorry worm
yes did try to repressurise the system but no movement.so if i connect the hot you belive it will pressurise the system.i didnt wont to because the hot at the moment is running off a water only boiler.but maybe ill have too.thanks
possibly,is the loop live?if the cold is turned off because of the dhw situation you may have no water going in
no the loop wasnt live,but as soon as the boiler is switched on there is no pressure at all.i know what im doing tomorrow! (hotwater)thanks
Reply to the thread, titled "no pressure on boiler pls help" which is posted in Boiler Advice Forum on Plumbers Forums.
