no water problem
View the thread, titled "no water problem" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
dave1
i have a problem with mains supply, on my in coming main i have a 22mm stopcock followed by 22mm non return valve then followed by what i think is a pressure reducing valve. i had no water coming through at all so i removed black cap off PRV and found a spring put it back together now im getting high pressure on the dial on the PRV when a tap is turned the dial swings round to low and gives medium to low pressure will i need a new PRV if that is what it is any way, had a plumber out he said must be problem with water board, im in a block of flats everyone else ok so i know it cant be that 😕
well whats the craic ,
they are temermental little xxxxxxxxxx s . swap it out mate for the sake of a few euro s.
Upvote 0
Reply to the thread, titled "no water problem" which is posted in Plumbing Advice for Any Other Country on Plumbers Forums.
dave1,
buffy27,
