M
mzuk04
Evening all.
I have a Worcester Bosch Combi Boiler 28i RSF, it was installed Nov 02 accordingly to the service booklet.
I have been in the house for 3yrs and decided I would get it serviced, so following the service several months ago the timer switch pin 'broke' and although would still work for often fall off.
I sourced a replacement timer myself and fitted it without too much hassel about a month ago (casing slid off, 2 screws to allow the main console panel to rotate down exposing the back, and then four screws holding the back panel on). However I struggled to get the 4th screw out so just about managed to remove the old timer and sneak in the new one, however at this point the plastic bit broke off that keeps the screw in place (left rear screw) however the backing panel was still tight.
Coincidental, after this, 50% of the time when I would use a hot tap and then finish using it, you could hear a fairly big noise from the boiler. But general running of the boiler for heating made no untoward noises.
Until last night when the boiler was buzzing constantly with the C/Heating, I could even hear it making the whining noise when I got home from the pub last night, outside, via the flu outlet. When the boiler is not being used there are no noises, when I only use hot water, something switches on and at this point is makes a 'buzzing, whining noise constantly' until I switch the water off, likewise with the heating, however if I have the heating on and then switch on a tap, theres a brief moment when 'it' makes a slightly different noise and then goes back to the original noise.
The noise seems to be coming from the Pump (it says Bosch on it) but obviously I cant be sure having no experience with boilers, any ideas?
Regards
Chris
Regards
Chris
