C
craig james
Hello out there: We have refurbished a bathroom, and the plumber hasshortened the outflow stack (which previously reached into the attic) so thatits top is now within the bathroom itself and has been boxed in and tiled,creating a small square shelf above the top of the stack (his idea, to give a"nicer" look to the bathroom). It has an Air Admittance Valve, and wenow hear a metallic tapping noise coming from behind the tiling when water hasbeen drained, and we assume this is the AAV valve opening and closing. Sometimesit’s an occasional tap, other times, one a second, other times more rapid. Theplumber has changed the AAV but it has not rectified the problem. If it is theAAV, should it be making this noise, and if so should it be so loud as to beheard through tiling and a boxed-in surround? Strangely, in a bid to solve the problem, the plumber fixed a restraint to the pipe stack itself within the box (not sure why). Since then it has reduced the amount of tapping noise when draining water in the bathroom but the tapping continues badly when draining units in the kitchen one floor below.
In case it's relevant, the AAV is above the outflow of the highest unit, the basin, by about 20cm.
Photo attached of the boxed in stack.
Also, the bath was relocated in the bathroom and obviouslynew pipework was put in. Now there is a gurgling noise from bath water as it finishesdraining. Is this to do with the AAV?
Thanks.
Thanks.
