View the thread, titled "Noisy baxi solo" which is posted in UK Plumbers Forums on UK Plumbers Forums.
abelag
Hi guys
Need some help with a baxi solo 24 he. It's making a loud buzzing noise once it's been on for about 20 minutes, it sounds like a fighter plane. It only does it when the heating is on and it's fine when only the hot water is on, any ideas? thanks.
Are you sure that it is the boiler making the buzzing noise?
If your answer is yes, then I suggest you consult a Gas Safe registered engineer.
Fan bearing once its warmed up, or running at low speed? Ketteling would occur on DHW and heating unless heating return was restricted or rads had lots of air in them? Have u checked too of hex and flue, seen some half full of aluminium flakes. Turn it right down and run do u get same noise?
Could be heat ex i had one where it was making a noise on heating side tried a fan wasnt that spoke to baxi they said gas valve or fan didnt change gas valve as wasnt convinced customer went o a contract turned out to be heat ex
Replaced it the noise only appeared after htg had been on for a whilei think it was originaly faulty and the instalelrs turnd down the boiler stat and when i serviced it it then appeared cos i put the boiler on high, turned it down and it dissapeared
That makes sense , cause one of the rads was stone cold the trv was stuck shut as soon as I loosened it up the noise stopped for about 5-10 mins (it obviously cooled the water down) then it come back on when it got hotter.
I had a chaffy last year that sounded like a lancaster bomber was in the house , as the heating got hotter the noise got louder that was the hex
Reply to the thread, titled "Noisy baxi solo" which is posted in UK Plumbers Forums on Electricians Forums.
