View the thread, titled "Noisy hot tank feed" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
mpk490p
my hot tank has started to make a noise like a hammer! it happens around 8-12secs after turning on any hot water tap, and can last for anything from 10 - 30 secs even if you turn the tap off
never had a issue like it in 15 years havnt turned the temp up or had any plumming done
2 thoughts one was the cold water feed to the tank so i got in the loft had someone else turn the hot on and as i moved the feed line it eased the noise
the other was a air lock but i did the cold to hot tap trick using mains pressure to force the aor back into the tank but it did nothing
thinking i just need to replace the feed valve in the hot water tank?
Replace the float valve with an equilibrium float valve will cure it.
Reply to the thread, titled "Noisy hot tank feed" which is posted in UK Plumbers Forums on Plumbers Forums.
