View the thread, titled "Noisy ignition on Ideal Logic + 24 combi" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Mike Jackson
Landlords check on a year old Logic + combi today with complaints from the neighbours of noise from "the pipe outside". Turned up and it was sounding like a fog horn when it fired. Anyone care to guess the problem?
I would be looking at a blockage in the gas supply as Gasman, firstly.
Also look at the joints in the flue assy, is the Logic + a telescopic flue or a cut with a blunt
blade type ! I have seen some shocking flue pipe cuts.
No to all 3. Should have said it's now running fine. It's a long gas run so my initial though was under gassed but I had 22 at meter and 21 at boiler on HW demand. Did it with cover off so I discounted air supply contamination problems. CO2 is factory set and no requirement to check on installation.
blocked condense i would say if it was an isar but logic + could be worth checking.
Zeb and MZR have it. Not blocked but condense pipe running uphill. Cut an inch off it and all was well.
Reply to the thread, titled "Noisy ignition on Ideal Logic + 24 combi" which is posted in UK Plumbers Forums on Electricians Forums.
