View the thread, titled "Noisy mains (like hammer)" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi guys/girls , can any body help? , i have a loud water hammer noise ,(like a fog horn) mainly at night,( when nothing is on) (and normally occurs twice within 30 seconds of each time) i have ;;; turned heating off , reduced pressure/ increased pressure, i have checked and replaced ball cocks in the loft, i have replaced stopcock , there is no connection with water running when this occurs, i have even heard and felt this noise on the rising main in the house when this happens,,, , no ball valves are leaking anywhere, toilets are all good.... has any body any ideas? i cant see the point in fitting a prv valve or dial ,, two months ago we had a water issue in the village , could this be connected? any help or advise would be appreciated . thanks mark
Hi Mark,
Is your incoming main copper/metal? If so I was told years ago, that the “foghorn” noise can travel, and also could be your neighbours property?
Reply to the thread, titled "Noisy mains (like hammer)" which is posted in UK Plumbers Forums on Electricians Forums.
