Hi guys, been to look at an old 35CDi II. Works fine on c/h, but open a hot tap.... boiler fires, heats up, starts knocking, pressure gage jumps about a bit, then it goes out. 10 secs later starts all over again. The pin in the diverter moves across ok & stays in dhw position while ever a hot tap is open, moves back fine when closed. It does this whether or not the heating's on. Don't know if this is normal for this model but when c/h is on & you open a hot tap, both c/h and dhw lights are on. Most other boilers I've come across switch between the 2.
Any idea please
Any idea please
