View the thread, titled "not enough hot water" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
Blocky
Hi
can anyone tell me why a H/W cylinder seems to run out of hot water water after one shower when there use to be enough for 3.
Are you heating it electrically via economy 7?
If so you Will have two immersion heaters and the bottom one has failed. The top one only heats the top third or so.
Upvote 0
No its via gas boiler. its seems to heat up normally but doesnt last
Upvote 0
Have you lived in the house long?
What could be happening, is that the cold water that you are mixing with the hot to shower in a nice warm spray is colder (as we are in Autumn not summer).
Therefore you will use more hot water to keep the water at a comfortable temp' and therefore it won't go as far. You could try turning the stat up on the cylinder. however be careful of scalding yourself.
Upvote 0
Reply to the thread, titled "not enough hot water" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
