View the thread, titled "notifying unvented cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
markfxy
I don't do enough unvented to justify paying my cps scheme for unvented, does anyone know the procedure for registering direct with building control?
Pretty sure you can Mark , but that is still a costly price depending on your council
Its simple, phone your local building control and inquire, they will then give you a control number for a fee. They will inspect and sign off if all is proper and if not charge you the same again to do the same again after whats not correct is rectified. I did the same with an annex I built and saved a good amount of money but I doubt that very much concerning an un-vented cylinder when a registered guy could do it when part of a competent persons scheme for a couple of quid
Just like gas safe. If your not part of a competent persons scheme. Your not meant to work on it. If you are G3 registered, I apologise. then you can notify them yourself.
You only need to be competent to install but registered to register its all straight forward
To be classed as competent, you need to be G3 registered.
I am, have been for years just seems a waste of money paying for cps when I might only do 1 or 2 a year
The competence is to have the certification to install, but to register you have to pay either way
I've got the certification to install g3 lasts for five years what I don't want is to pay nappit/nic every year
Reply to the thread, titled "notifying unvented cylinder" which is posted in UK Plumbers Forums on Plumbers Forums.
