Odour from internal manhole cover - how to seal?
View the thread, titled "Odour from internal manhole cover - how to seal?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I've an internal manhole cover in my garage, covering the main waste drains. Only moved into the house about 6 weeks ago but noticed it occasionally smells a bit cabbagey around the area of the cover.
Have lifted, checked for blockage and cleaned out somewhat but still get a bit of smell now and then. Looking at the cover, it looks like the seal might be past its best, so I was thinking of applying a good layer of manhole grease around the edges but wanted to see if anyone had any better suggestions?
Thanks,
Ben
Thanks RPM, do I need manhole grease or could I use some alternative from Screwfix etc. that's available in a smaller quantity? (ideally don't want to spend £35 on a 3kg tub of grease)
Well, going by another post on the same subject somewhere else recently a respected poster said even Vaseline would do, of course any nicks in the seal and it wont seal properly.
Understood. I might remove the old rubber seal and replace with something similar before applying grease. At the moment, the old seal has gaps in it. This might be a dumb question but does it matter what shape the seal is, as long as it fits into the groves? E.g. this Stormguard EPDM Rubber P Strip White 20m - https://www.NoLinkingToThis/p/stormguard-epdm-rubber-p-strip-white-20m/33145#product_additional_details_container looks different from the seal that's currently in there but not sure if I can find an exact like for like
Hi Boothus,
Could you give me an update? Still fine? I have a very similar problem.
I wonder if you could add the name of the silicone grease you used.
Reply to the thread, titled "Odour from internal manhole cover - how to seal?" which is posted in UK Plumbers Forums on Plumbers Forums.
Boothus,
Lou,
