M
Martin O
I have an oil fired Grant Boiler, it is constantly locking out, there is plenty of oil in the tank, it has been bled through several times but air is constantly getting into the line causing it to lock out.
It has an old steel tank which has a plastic tube fuel level gauge, what I have noticed is that when the boiler fires and runs ( It can run for 2 minutes or an hour) the fuel from the gauge is emptied and drawn back into the tank, when the boiler locks out the oil fills back into the gauge but with air bubbles in it, also when the boiler is running is sounds like someone is having a bath in the oil tank the oil is swirling and lapping against the sides... is this normal ? Can it be pulling air in or is it possible all the oil movement is creating air in the tank.
