Oil boiler in low water pressure location. Pump problem.
View the thread, titled "Oil boiler in low water pressure location. Pump problem." which is posted in Boiler Advice Forum on UK Plumbers Forums.
No not that don’t twist that
You will either have an auto vent or two like what you have in your rads
Hi John, back late. But I have run the system again without problem. You asked about way to purge at boiler top. Is this it? And if so, is it obvious what to do with it?it looks like a 3bar PRV but too much electrics
Hi John, back late. But I have run the system again without problem. You asked about way to purge at boiler top. Is this it? And if so, is it obvious what to do with it?View attachment 64219
No, leave well enough alone as you are now running OK. I am not familiar with that type of PRV as it seems to have a temperature capilliary attached to it, just from a safety aspect ensure that the other side of the PRV is attached to a pipe that goes to waste.
This is what a PRV looks like with that open end going to drain.
shopping
I think I might have been on those lines when I reduced temp of boiler. Gotcha re valve, I'm going to progress some of these points tomorrow. I've turned the pump down to 2, which is where I thought it was, and retry.
The two thermostat (control&hi limit) sensors are located where shown, they are in a dry pocket that is screwed into the top of the boiler.
Reply to the thread, titled "Oil boiler in low water pressure location. Pump problem." which is posted in Boiler Advice Forum on Plumbers Forums.
stevef,
John.g,
