View the thread, titled "oil boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
rubberman 20
I have a solid fuel central heating system which also heats the hot water.
I want to install an oil boiler to run with the solid fuel, As anyone done this and if so please can they advise if it can be done?
Not fitted one of these systems myself but it's definitely possible and not unusual to see these systems out in the sticks.
Probably best to find someone who is both OFTEC (oil) and HETAS (solid fuel) qualified then they should know what they're talking about.
check out Dunsley [DLMURL="http://www.dunsleyheat.co.uk/neutralizerpics.htm"]dunsleyheat uk manufacturers of multifuel stoves, range cookers, boilers...[/DLMURL]
This is one way of doing it, but you need someone who knowes what they are doing to do it, it isn't a diy job!
Reply to the thread, titled "oil boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
