Hi my oil burner has started to turn on randomly. It doesn't heat anything but I can hear it running outside. What could be causing this.? The timer is set to off
Then I suspect the hot water zone valve has failed. I take it you have two 2 ports in the airing cupboard?
You need someone with a multimeter and an understanding. If it is a 3 port valve I suspect a dodgy programmer.
Thanks. You have two 2 port valves. One for central heating and one for hot water. I suspect the hot water valve has failed keeping the boiler energised. This can be caused by a seized valve, seized motor or the springs to return the valve have failed.
You need someone to electrically test this to confirm my suspicions.
Ok thank you very much for all your help. I will get someone to have a look at it. Which one is the hot water one do you know. Again thanks for the help
