View the thread, titled "oil heating / back boiler issue" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Daryl Doherty
open fire lit for the winter, hasnt been lit in years.
lit it up anyway, and the radiators are all heating fine! then the pump to heat the downstairs radiators is fine aswell!
the main problem here now is that the back boiler doesnt seem to be heating the tap water.
we turned on the oil boiler to heat the water early this morning and the outside boiler wont fire up at all, it was working fine last night. (the fire was lit at this time too)
any ideas or advise? thanks in advance
Daryl
Need a lot more to go on. How's the back boiler and oil boiler tied together, is the oil boiler locking out, what sort of oil boiler,,,,,???
Put a bit more flesh on the bones and may be able to point you in right direction.
tap water now heated via the back boiler so that is ok.
ive no idea as to how they are linked.
basically >
fire, heats all upstairs radiators and water.
pump then circulates water to the rest of radiators.
oil heating heats everything in the house. but oil heating is not firing up (since this morning)
If that's as much detail that you can give then find yourself an oftec engineer to have a look.
Good luck.
Has oil boiler gone to lock out? When power is going to boiler a button on the burner of boiler may be lit. Press it & it should attempt to start.
Good luck.
I thought you were a psychic and used ESP?
:arabia:
Must admit, could be all manner of things at the moment but my money's on the suggestion that the boiler might have locked out.
:arabia:
I wish, I'd be winning the lottery every week. I'd also had a few quid on man u and chelsea getting beat today.
My response does seem a little blunt now that I've re-read it but, can't help with the info given, could be no oil or somebody could have knicked the boiler! 🙂
Reply to the thread, titled "oil heating / back boiler issue" which is posted in Boiler Advice Forum on Plumbers Forums.
