View the thread, titled "Old steel pipe thread size" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
ma701ss
Hi, I tried to fit a new basin yesterday, the taps are connected to old steel pipe in my 30's house. The thread on the steel t-piece is slightly larger than 22mm, more like 23mm or perhaps of imperial it's supposed to be 7/8 inch. I need a coupler from this thread to 15mm but can't find any. Does anybody know where I could get one? I'm not a plumber and just wanted to do the bare minimum as temporary solution.
Hi, thanks I think you're right. I understand it now having looked at bspt.co.uk. I'm trying to connect up to old steel and lead pipework. Think it may be time to renew but in the words of my good friend Mick Hucknall, money's too tight to mention. I have lead mains going into loft and then back down to the kitchen. From the tank in the loft to the bathroom there is also lead cold pipework. I found online a 50m coil of speedfit plastic pipework for £40. Just wondered if I could use this and find a larger size for the water main, and then run all of it in one length without any joints (except where needed to branch off)? Might be easy for me to do then.
No didn't try that, I don't have one. It measures 23mm so assuming it must be 5/8 bsp.
You should really replace all the lead and steel pipe work, that lead will be 85 years old and well past its time, any slight movement or stress could cause it to leak, not to mention it breaking down into the water your drinking
If it's also lead in the ground outside the house though, probably not much point changing it for health and safety reasons?
Reply to the thread, titled "Old steel pipe thread size" which is posted in UK Plumbers Forums on Electricians Forums.
