View the thread, titled "old steel water pipe" which is posted in Bathroom Advice on UK Plumbers Forums.
A
adrianfs1
hi all not been on here for a long while, hope all are well,
can anyone advise me as to the best way to repair a corroded steel water pipe, i have already removed the corroded area of the pipe of which i believe is about 20mm outside diameter, now got to repair it, it is situated about 600mm down but in a farm yard with a lot of heavy machinery passing over it, is alkathene the preferred option bearing in mind the old steel pipe is rough on the surface but is still solid, or would you guys prefer to use compression fittings, all advice appreciated, speak later.
it will be iron not steel!
best thing to do is replace the whole lot. probably not what you wanted to hear......but to prove a point if you just cut out the damaged section first with a view to making a repair, just look at the inside of the pipe, it will be full of crud and i mean full! its really disgusting and this is supplying your drinking water!!!
KJ
Mains and service pipes should be at least 750mm beneath the ground to protect from frost damage, but no deeper than 1350mm for ease of access. Also if you are going to replace the lot, 25mm blue MDPE is the best choice (all new service pipes are made from it!)
Reply to the thread, titled "old steel water pipe" which is posted in Bathroom Advice on Plumbers Forums.
