View the thread, titled "Old system air problems+noise" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Y
Yardmaster
hi guys
i have a open vented system
radiators where cold at bottom, so i removed them all and flushed them out, true enough they where full of dirt
anyway, i seem to have a radiator that needs constaint bleeding, that was ok so i replaced it with another one, a
no difference needs constaint bleeding everyday, obviously air is getting in somewhere, any ideas?
also you can hear a flushing of water everytime you turn the heat on only on this rad.
also on another issue the mains pipe going up through the hot press, is making vibration noises, this never happened before. so i tried turning down the pressure outside but still no joy.
:iagree: system may have a restriction or the pipework is configured incorrectly? draining down can increase the likelihood of problems occurring ...!
Reply to the thread, titled "Old system air problems+noise" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
